Flowform FF04a
Merhaba!
I saw in your forum you are interested in building a Flowform. With a friend I could get some information about your posts in the forum.
One of you is going to build a small FF04A with about 1 metre spanwidth. In my opinion that kite is too small and perhaps will not fly as stable as a larger one. I would say a spanwidth of 1.5 metres is working much better.
A large FF04A with 4 metres spanwidth is not a problem. Of course, it is not easy to start for one alone. But with two persons (one on each side) opening the inlets and one person at the flying line it is no problem. With fixing the flying line to an anchor and opening the inlets from one side it is even possible to start the kite by one person. Of course depending on the size the pull is powerful if the windspeed increases. For the FF04 with 4 metres spanwidth I needed about 75 sqare metres of fabric (and I had no applications).
For KAP I would not take the large Flowform with 4 metres spanwidth. Of course it is no problem to lift the rig but you cannot go around with the flying kite ;-)
Okay, I hope these information is helpful for you. Feel free to ask, if you have more questions.
In the year 2000 I had contact with Ferruh Baysu. He made the American Flowform. I think you know him and perhaps he is so kind to give you help in your language, too.
Nice breezes from northern germany
Harald Prinzler
http://www.members.aol.com/hprinzler
Kite Aerial Photography and Flowform Information
Merhaba!
Sizlerden biri 1 metrelik FF04A yapıyormuş. Benim görüşüm bu fazla küçük olur ve büyüğü kadar stabil olmayabilir. En azından 1.5 metre olması daha iyi olabilir.
4 metrelik olanı sorun olmaz. Tabii ki uçurmak için iki kişinin yanlardan tutması ve birinin havalandırması gerekir. İp bir kazığa bağlanırsa bir kişi tarafından bile havalandırılabilir. Boyutu nedeni ile özellikle rüzgar güçlendiğinde çekişi çok fazla olacaktır. 4 metrelik FF04 75 m² kumaş gerekiyor.
Kap için bu boy uçurtmaya gerek yok.
Umarım bu bilgiler size yardımcı olur. Sorunuz olursa cevaplamaya hazırım. 2000 yılında Ferruh Baysu iletişim kurmuştuk. O American Flowform yaptı. Kendisi size yardımcı olacaktır.
Kuzey Almanya'dan iyi rüzgarlar dilerim.
Harald Prinzler
Re: Flowform FF04a
Post by yigitkahraman »
Molar Flowform için bugün çizimlere başlıyorum.
Planı detayları ile inceledim. Harald Prinzler 'in mailine göre düzgün uçuş için büyük olmasının şart olduğunu anlaşılıyor. Aynı zamanda benim için de ilk tecrübe olması sebebiyle; biraz küçük ama planı *2,5 katı yani 2000mm*2500mm olarak düşünüyorum.
Re: Flowform FF04a
Yiğit, bu aslında bir Sutton flowform. Şeklinden dolayı Molar flowformda diyen var ama asıl başka bşr molar flowform var.
*2,5 derken de sanırım*0,5 yazacaktın.
Re: Flowform FF04a
Bu arada Steve Sutton'dan da biraz bahsedelim.
Kendisi aslında Kanadalı bir gökyüzücü dalıcısı. 19 yaşında iken paraşütle atlamaya başlamış daha sonra Kanada ulucal paraşüt takımına katılmış. Bu sürede paraşüt dizaynları üzerinde çalışırken, Sutton Flowform uçurtmasını geliştirmiş.
Uçurtmadan bahsetmek gerekirse Diğer foillere göre daha dengeli uçuyor. Bunun sebebi alt ve üstteki hava deliklerinin rüzgar direncini düşürmesi ve uçurtma içindeki hava basıncını düzenlemsi.
Patent:
http://kitepatents.blogspot.com/2006/06 ... 22844.html
Re: Flowform FF04a
Bilgiler süper oldu teşekkürler.
Re: Flowform FF04a
Bu arada Yiğit Planda 1000x800 yazdığını söyledi. Bu doğru ancak uçurtmanın orjinal boyu 4x5 metre. Harald Prinzler ile yıllar önce FF03 ü yaparken görüştüğümde ff04'ün bu boyutlarda olduğunu söylemişti.
Bilgi vermişken devam edeyim. İlk piyasaya çıkan Sutton flowformlar Sutton #252, #450 vs. şeklinde piyasaya çıkmıştı. Hala satılmakta. Daha sonra Harald Prinzler ff03 ve ff04'ü geliştirdi. Son olarak daHQ Harald, Pinzlerin planına çok yakın bir uçurtma üretti.
Sutton 252 ve 450: 8 panel, 5 keel.
http://www.foreverflying.com/sutton-flowform450.html
http://www.foreverflying.com/sutton-flowform252.html
Sutton 125: 6 Panel, 4 Keel.
http://www.foreverflying.com/sutton-flowform125.html
Sutton 4-60: 4 Panel, 3 Keel
http://www.foreverflying.com/sutton-flowform60.html
HQ Flowform
http://www.invento-hq.com/index.php?opt ... &Itemid=44
Re: Flowform FF04a
Abilerim, kalıpları lütfen atmayalım bende yapmayı düşünüyorum,
Re: Flowform FF04a
Kumaş çok ince olduğu için ekstra 2 kat daha fazla uğraşmak zorunda kaldım. Dikiş yerlerini güçlendirmek için gizli biye yapılması ve esnemeyi önleyici çalışmalar uçurtma yapımından daha fazla zamanımı aldı.
http://yigitkahraman.files.wordpress.co ... ag0074.jpg
http://yigitkahraman.files.wordpress.co ... ag0067.jpg
http://yigitkahraman.files.wordpress.co ... ag0078.jpg
http://yigitkahraman.wordpress.com/2011 ... lowform-2/
Re: Flowform FF04a
Post by mustafa-topcu »
Yiğit abi,Flowform FF04A mükemmel olmuş.Bu foiller,en sevdiğim uçurtma kategorisinde yer alıyor.Böylesine güzel bir uçurtmayı paylaştığınız için teşekkürler.
Uçurtmanın boyutlarını paylaşabilir misiniz?Sanırım bu tür uçurtmalarda çıta kullanılmıyor değil mi?
Re: Flowform FF04a
Yiğit şahane bir şey yapmışsın. Haftanın uçurtması oldu galiba. 8)
